XC90 mk1 d5 brake issues
Old Nov 3, 2022 | 03:39 PM
LinasJuska's Avatar
Default XC90 mk1 d5 brake issues
Hi, people, I know, probably this topick was already discussed, tried to find, but it took ages with no results.
Problem with brakes on xc90 2006 model, brake booster was leaking vacuum, replaced it with original part, got some other issues with some sensors etc, so... booster replaces, vacuum pump replaced, fluid replaced, pads, discs, bcm, acceleration sensor replaced... still no brake, there is some, but it looks like booster not working, any clues anyone? Sitting stuck with it since april. Help, please.
Old Nov 3, 2022 | 09:32 PM
are you sure its the booster leaking vs a problem with the vacuum lines ? I believe there's a check valve in there... Do you get good braking pressure (albeit with a firm pedal) or do you have a soft pedal with no braking pressure?
Old Nov 7, 2022 | 09:36 AM
LinasJuska's Avatar
Hi, pedal is hard and it is not going down or getting softer, when I start engine. I have checked everything n times, no problem found... I will check vacuum line one more time, just to be sure if there is vacuum in booster. Booster is brand new ATE, vacuum pump new too.
Old Nov 10, 2022 | 11:38 AM
LinasJuska's Avatar
Hi again, checked everything once more today, vacuum pump is working, hose looks ok and it looks like I have vacuum in the booster as well, but still it is not working, starting to think that booster is defect, which is sad, I have replaced it twice, I don not believe, that boutho boosters are gone, any ideas?
VolvoXC90.2004
Mar 14, 2022 03:23 PM
Erik1000
Mar 25, 2017 09:04 PM
Nestor1221
Mar 9, 2016 10:52 PM
dajson
May 30, 2013 11:48 AM
Greenmudshark
Nov 11, 2010 08:15 PM
