XC90 T6 Transmission problem
Old Feb 1, 2016 | 12:56 PM
cdsonycd's Avatar
Exclamation XC90 T6 Transmission problem
Dear friends, am just new in this forum.
I have a XC90 t6 AWD 160Miles, I bought it as used one.
1, The speed/transmission once reached to 40 speed or third gear, its don't want to shift to 4th gear, then the error message comes 'transmission service urgent', then I switched off the vehicle and restart... its ok if am driving through a straight road, transmission shifts gear without any issue, if am driving through a slow moving traffic, then the same problem repeats.its only in 3rd gear...
2, another issue, the electrical power shut down sometimes, all panel boards, lights, and 5th gear automatically down to 4th, so many error messages, some posts are showing that, its the problem of CEM,
My first problem also because of the CEM complaint?
What should I do? Please help somebody.
Old Feb 1, 2016 | 05:11 PM
to the forum cdsonycd
Moved to the XC90 sub forum.
Old Feb 2, 2016 | 01:14 PM
cdsonycd's Avatar
Thank you brother
Hope you can help about my issue
Old Feb 3, 2016 | 07:43 AM
ES6T's Avatar
There is really nothing you can do on the internet. You need the codes. Probably not going to be worth fixing.
Old Mar 30, 2016 | 02:50 PM
sketch's Avatar
the transmission is going to need to be replaced/rebuilt. triple edge performance is one of the better shops around that works on our transmissions, i got the vast majority of parts for my transmission rebuild through them.
any other codes you can pull will be helpful in diagnosing, hope this reply isn't too late
Old Apr 22, 2017 | 03:15 PM
johnpjusa's Avatar
Volvo have problem with the software there is some glitch in it and Volvo dealers know it but they are greedy and dishonest they start wit replacing the fluid and then the transmission to make many on you guys . Only what you need is updating the software for both engine and transmission which is only 50$. I been there twice first they told me what if the engine will stop after update who will pay to fix it they told me no dealer in usa going to do it. I found someone els to do it for 300$ it helped...
dhg
Apr 25, 2017 10:48 AM
jefflee137
Apr 22, 2017 03:12 PM
Rswitz
Jan 31, 2011 05:14 PM
zral
Sep 27, 2009 01:48 AM
magyarxc90
Oct 14, 2007 04:31 PM
