XC90 Transmission
Old Jun 25, 2019 | 10:16 AM
skifast's Avatar
Default XC90 Transmission
I am looking at two 2008 XC90s. One has an inline 6 and the other a V8. Both have around 100,000 miles.
My concern is the transmissions. I have read online that the transmission problems are common. I am also old enough to know that the Internet is full of information, some true and mostly false. Do XC90s have widespread transmission problems? If I buy one of these vehicles, will I be replacing there transmissions?
Second, I believe the V8 uses a timing chain. Is this correct? Does the I6 use a timing belt?
Thanks,
Old Jun 26, 2019 | 12:37 PM
most of the issues with the AWD transmissions were from the early 00s - pre 2004. the 2008s don't share the same model transmissions so that's not a widespread problem area. Yes the V8 uses a timing chain and the I6 and T5s use timing belts. With that said you should still have a professional inspection done and see if the seller has a full maintenance history before buying any used car.
Linda Womack
Jul 10, 2019 09:22 PM
wdg8769
Feb 24, 2018 09:30 AM
InJapan
Mar 1, 2008 01:28 AM
cbearing
Nov 25, 2005 05:43 PM
