Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
960 rims fit 2000 V70?
Old Nov 24, 2011 | 09:43 PM
guiness's Avatar
Default 960 rims fit 2000 V70?
Will a set of OEM rims from a 960 wagon fit my 2000 V70 wagon?
Old Dec 1, 2011 | 07:05 AM
S70driver's Avatar
If they are 5x108mm bolt pattern the answer is YES. However wasn't the 960 RWD so the offset might be different then your V70. So then spacers might be needed to make them work properly.
Old Dec 11, 2011 | 10:34 AM
AdrianL's Avatar
Check the center bore of the wheels too, you may need rings. FWD vs RWD shouldn't be an issue as I don't think this model came with staggered wheels. As long as your bolt pattern is right, then worst case scenario you need the rings as I said, which aren't expensive.
Old Jul 18, 2012 | 01:25 PM
SocolW's Avatar
This site comes in handy to those who want to shop around for wheels.
WheelsAnything.com - Aftermarket & OEM Wheels Tires and Rims
87 740 turbo wagon
Feb 20, 2014 08:50 PM
scubblicious
Jan 2, 2008 08:56 PM
0Trek0
Nov 6, 2005 11:28 PM
beckington
Sep 8, 2005 11:45 PM
brushfires60
Jun 15, 2005 12:27 AM
