v70 wheel alignment -how much should it cost ?
Old 08-02-2013, 12:17 PM
hockeyfool's Avatar
Default v70 wheel alignment -how much should it cost ?
I have 2003 v70 - non turbo , replaced control arms & stabilizer bar ; now I need an alignment - how much should shops charge and does it need to be 4 wheel aligned ??
Any help appreciated !
Old 08-02-2013, 12:33 PM
ES6T's Avatar
Varies from shop to shop. Anywhere from $80-$140. And yes, you need a four wheel alignment.
Old 03-26-2014, 07:20 AM
neokhz's Avatar
Tires plus does 4-wheel alignments for $79
Old 03-30-2014, 04:34 AM
stop_at_willoughby's Avatar
Hope you did the ball joints. Especially if you paid to have it done. Labor on a European car you are crazy not to replace ball joints with the control arms. I would have also got IPD inserts for the sub-frame bushings considering the age of the car. Also check the transmission and engine mount. Doing so would have ensured your suspension was completely solid.
About $80 for alignment front and back. If you get just front alignment can get it for like $60.
Old 03-30-2014, 08:33 AM
ES6T's Avatar
If the rear has adjustments points, a front wheel alignment is a total waste of money.
Shibby
09-01-2023 06:45 AM
mrvolvos60
09-11-2014 07:39 PM
manoduv
08-03-2013 06:50 PM
master_pre
09-30-2006 04:35 PM
Quick Reply: v70 wheel alignment -how much should it cost ?
