1991 Volvo 240 Won't Start
Old 08-09-2014, 06:52 AM
GlennDeGuire's Avatar
Default 1991 Volvo 240 Won't Start
Good Day,
I have a 1991 Volvo 240 Wagon that is turning into a puzzle. Went out about a month ago to move it into my garage. It started but then quit when I hit the accelerator. Since then, it just turns over but won't fire. Thus far I have replaced the fuel system relay, the coil, the Fuel Injector ECU, the Power Stage, the Ignition System ECU, both fuses at #4 and #6, and the CPS. I have power at the coil and have power at fuse #6. I jumped power from fuse #4 to fuse #6 and the fuel pump comes on underneath the car but the car still will not fire up. Checked for codes (Nothing) Getting 1 1 1. Put gas in the tank. Checked wiring, all looks okay. Replaced the Throttle Position Sensor. Also found a thin vacuum hose to be broken from the throttle down near a canister. What should I be looking for next? I'm stuck. I'm thinking that I should trace to see where the power stops. Also the cam is turning. Timing belt was changed about 5000 miles ago. Thanks in advance for your help.
sarahshufelt
05-24-2015 08:42 PM
GlennDeGuire
08-24-2014 11:08 PM
RDeSant86
01-19-2012 10:05 PM
RustyDog
08-09-2009 12:30 PM
dstinsman
01-13-2008 10:59 AM
Quick Reply: 1991 Volvo 240 Won't Start
