Lola's Progress Log
Old Aug 18, 2010 | 01:44 PM
  #501
Legendsecko87's Avatar
Well, I got the transmission fixed. Just bought a used one from Aurora Auto Wrecking up in North Seattle and it went in easy. Swapped over the PNP switch, put in some bright red ATF, rather then the brown that was in there along with some new coolant and it works like a charm! I'm happy that my car actually moves now. The only problem I have with it is that I hear a slight whine when in gear. Anybody think this will eventually go away or is this just a woe since I have a used tranny?
Old Aug 19, 2010 | 09:29 PM
  #502
Is the fluid low?
Old Aug 19, 2010 | 11:17 PM
  #503
There's more then enough!
Old Aug 20, 2010 | 08:22 PM
  #504
Did it get dark?
If not drive it some more and see what happens.
Old Aug 20, 2010 | 09:01 PM
  #505
boxpin's Avatar
If the fluid is up there is not much you can do from the outside. You may have to live with it. Bummer.
Old Aug 21, 2010 | 12:35 PM
  #506
That's what I'm thinking. Oh well. I'll have to wait until the transmission dies to get a new one :P. But the fluid is a good color.
I just made it up to Lake Chelan, a good 3.5 Hour drive from Seattle. Transmission held up like a champ in 3rd gear pull when passing people at 80+MPH. I also got a good 30+MPG with the FMIC instalation, that's on the trip computer anyways. I never got that high on the trip computer off the stock intercooler. Maybe 26-27MPG.
Old Dec 6, 2010 | 08:24 PM
  #507
Hmm, any way to fix hard shifting? I'm starting to see hard shifting, but everything seems fine except for the whine.
Ps. Sorry i've been dead for a while.
Old Dec 6, 2010 | 09:30 PM
  #508
You mean like dropping into gear? How's your lower torque mount?
Mine seems to be down shifting a little hard and it shifts hard when I go into reverse to back into my garage. Also seems like it's starting to slip a little. How do you check the fluid level on these?
Old Dec 11, 2010 | 07:58 AM
  #509
Is the fluid dark?
Old Dec 13, 2010 | 12:54 PM
  #510
From shifting to 1st to 2nd seems to be a lot harsher then it was on my old transmission. Fluid is still good. After the install of the used transmission it was put in with brand new fluid. I should have gotten some Lucas, however I'm already at the top of the fluid line, so I don't think I can put anything else in there unless I drain some.
Old Dec 13, 2010 | 09:28 PM
  #511
How old is the lower transmission mount?
Old Dec 14, 2010 | 01:57 PM
  #512
couldn't tell you. Would that cause it even if it's only between 1st and 2nd?
Old Dec 16, 2010 | 07:32 AM
  #513
The rubber gets soft or torn. The torque of changing gear causes a whipping effect.
http://www.ipdusa.com/Volvo-850/Engi...-153-249-3326/
When we first got our S70, it was shifting hard between 1st and 2nd. I replaced them on both of my cars. Made a big difference. The ones from ipd do transmit vibration so if you don't want that, get the oem one from FCP.
tech
Forum Issues
12
Mar 19, 2017 11:30 AM
JPN
Forum Issues
Mar 26, 2009 08:26 AM
uncle
Forum Issues
Apr 28, 2008 08:31 PM
TheSteelKnight
Sep 15, 2007 11:51 AM
KINGI5T850
May 8, 2006 01:38 AM
