Bevel (angle) gear oil change
Old Mar 21, 2007 | 02:14 PM
Psaboic's Avatar
Default Bevel (angle) gear oil change
All,
I want to change the oil in the bevel gear housnig in the wife's 01 XC 70 as a preventative measure (the car has 62K on it). Is there a special "one of a kind" fluid I need to use like we have to in our transmissions, or will good old synthetic 75W90 gear oil work?
Thanks in advance for any advice,
Glenn
Old Mar 26, 2007 | 01:35 AM
jbx2's Avatar
Default RE: Bevel (angle) gear oil change
According to VADIS:
Only use transmission fluid.
P/N: 1161513-5
Correct volume: 750 ml.
Tighten the level plug. Tighten to 35 Nm
Old Sep 18, 2022 | 02:40 PM
jrobbyiii's Avatar
Default Vadis ??
Originally Posted by jbx2
According to VADIS:
P/N: 1161513-5
what is VADIS??? Why wouldn’t a synthetic 70/90 work well in a mechanical differential with no clutches?
Old Sep 20, 2022 | 01:58 PM
VADIS is the Windows precursor to VIDA. Since the angle gear (bevel gear) only takes less than a quart, why not simply buy the OEM part #? IPD, FCP and dealer stores all carry PN# 1161513-5 for about $25. From what I've read its just a 75-90wt GL5 oil so you could research for something from Redline, Amsoil etc. There's a different part number listed for the rear differential so not sure what is needed there. (rear diff takes like 1.3L...)
Old Sep 20, 2022 | 02:01 PM
jrobbyiii's Avatar
Because Valvoline full synthetic is much cheaper. Are you an OEM Volvo parts rep or something?
Old Sep 20, 2022 | 02:30 PM
as noted you can go shop for a GL5 75-90 and save $5. Walmart sells Redline, Valvoline, Mobil1 (all synthetic) for $22 a quart.
drenman
2001-2013 model year XC70
Sep 27, 2015 08:50 PM
texan_176
Oct 13, 2009 09:04 PM
petes99xc
Apr 18, 2009 07:49 AM
petes99xc
Oct 26, 2008 07:59 AM
raducu76
Jul 26, 2008 08:31 AM
