S40 Variable Valve Timing Hub
Old Mar 10, 2005 | 05:11 PM
ajwgtor's Avatar
Default S40 Variable Valve Timing Hub
Can this puppy be cleaned or does it require replacing? 2000 Volvo S40 w/60K miles. Thanks for any input.
Old Mar 10, 2005 | 08:33 PM
Default RE: S40 Variable Valve Timing Hub
Why are you asking what is wrong?
Old Mar 15, 2005 | 11:11 AM
ajwgtor's Avatar
Dealer states that the hub needs replacing and I assume it is a code that is telling them that. From what I can see, this hub is just a hydraulic actuator that advances or retards the cam from ECM inputs by directing the CVVT Valve to send oil pressure to one side of the hub or the other. No sensors in the hub that I can determine. It seems to me that an "actuator" can be rebuilt and or cleaned.
Old Mar 15, 2005 | 11:32 AM
Im not sure if you can clean it or not.You might not be able to get everything out.The VVT valve might be faulty.
rmc2010
Dec 5, 2016 11:05 PM
puxnstx
Dec 13, 2014 11:36 AM
essayons07
Jun 2, 2014 09:36 AM
Lab_Rodent
Nov 27, 2011 11:20 PM
jessica16827
Jun 21, 2008 05:40 PM
