Variable Valve Timing diagram of the S80?
Old Dec 9, 2007 | 09:25 PM
Lab_Rodent's Avatar
Default Variable Valve Timing diagram of the S80?
Does anyone have an engine diagram showing the CVVT (continuous variable valve timing) set up around the cams of an S80?
Old Dec 9, 2007 | 10:21 PM
Default RE: Variable Valve Timing diagram of the S80?
What exactly do you need?
Are you wanting to do seals?
Old Dec 10, 2007 | 02:13 AM
Lab_Rodent's Avatar
No, just wondering how it works in case I wanted to tune the cam timing. Honda's "VTEC" uses a shaft to engage one pair of valves at certain times. I was thinking this may be something similar. I have the info now and see it is quite different. It just isnt Variable Valve, the word "Timing" is literal. If you could find a programmer that could fully program this function you could get significant performance increase. But at stock, it is tuned for economy.
Old Dec 10, 2007 | 05:37 PM
Yes it is a PITA setup.
Espically once you try to work on it.
Old Dec 10, 2007 | 09:02 PM
Lab_Rodent's Avatar
Yeah, and some guy on this other site keeps arguing with me about it. Trying to tell me that there were a lot of aftermarket ECUs that I could use. I narrowed his list down to 3, which 2 of them were UK brands I have never heard of, and the other is MOTEC. I dunno' if any will allow the use of the stock gauges.
Old Dec 10, 2007 | 09:07 PM
What about IPD?
And some of the other company's that list the S80?
Not good company's?
Old Dec 10, 2007 | 09:09 PM
Have you tried them?
Thats the chip I have in my R.
http://www.upsolute.com/index.php?op...dels&id=24
Old Dec 10, 2007 | 09:20 PM
Lab_Rodent's Avatar
A chip is no where near what I was looking for in performance. IPD's are way to expensive for what they do. You should be able to buy a fully functional programmer for this car, not just a flash tuner (like IPD's). For some reason no one has made one available for the public.
Old Dec 11, 2007 | 05:27 PM
Oh ok
Old Dec 11, 2007 | 11:56 PM
Lab_Rodent's Avatar
but FYI, I prolly' will end up getting a chip type tune and call it quits for the S80.
Old Dec 12, 2007 | 05:23 PM
Cool let us know how it comes out.
Old Nov 27, 2011 | 11:20 PM
Socrates Ebo's Avatar
how do i get the setting of the s80 timing belt right?
essayons07
Jun 2, 2014 09:36 AM
jessica16827
Jun 21, 2008 05:40 PM
KINGI5T850
Apr 15, 2006 07:25 PM
ajwgtor
Mar 15, 2005 11:32 AM
