variable timing gear at rest position
Old Jun 1, 2014 | 08:26 PM
essayons07's Avatar
Default variable timing gear at rest position
Well I thought I was doing good replacing the timing belt and seals on my sons S60 until I neglected to mark the "at rest" position for the variable timing exhaust cam. Is there a way to determine the at rest position?
Really ticks me off..I usually have the car serviced. My mechanic never told me about the PCV system so at 200,000+ miles the s60 blew the cam seals.
thanks in advance
Old Jun 1, 2014 | 09:16 PM
Dons Sportcar's Avatar
Take the cas sensor off the back of the head and make sure that line on the cam is flat with the head wherever is close by then make sure that stays in place rotate the vvt cam all the way to the mark on the timing cover and slap the belt on
Old Jun 1, 2014 | 09:33 PM
essayons07's Avatar
Wow, that simple? Thank you...
Old Jun 2, 2014 | 01:50 AM
Probably should have put rotate counterclockwise to mark
Old Jun 2, 2014 | 09:36 AM
essayons07's Avatar
thanks!!...I had to think about it for a second but it makes sense!
Lab_Rodent
Nov 27, 2011 11:20 PM
ridextream53
Feb 12, 2011 08:36 PM
jessica16827
Jun 21, 2008 05:40 PM
skipb
Jul 6, 2006 10:45 PM
ajwgtor
Mar 15, 2005 11:32 AM
