turbo swap /upgrade
Old Mar 19, 2005 | 01:28 PM
blkwgnt5r's Avatar
Default turbo swap /upgrade
what is an upgrade for this size turbo(tdo4h comp side)(t1800t exh side)this is currently on my 1995 850 t5r ..it died(turbo) im looking for a factory upgrade bigger turbo.. what yyears can i swap with s70t5-v70t5 etc..thanks for any info
Old Apr 11, 2005 | 04:17 PM
BlackT5's Avatar
Default RE: turbo swap /upgrade
Your turbo (TD04HL-15G) uses a conic flange for the downpipe connection. If you want to upgrade to a larger turbo from a newer model (16T, 18T, 19T) you will have to change your downpipe. An upgrade to 18T or 19T would need new injectors also. Plus you will have to get your ECU reprogrammed for the larger turbo to ensure you have enough fuel.
www.volvospeed.com forums has lots of info on these types of upgrades.
Old Apr 11, 2005 | 10:22 PM
alecw81's Avatar
You don't necc. need to reprogram your ECU for that though, you can use a piggy-back module like the Apex-i SAFC (air-fuel computer)
Old Apr 12, 2005 | 02:44 PM
BlackT5's Avatar
People who have tried the SAFC say it does nothing above 4000rpms. There are amny posts about this on Volvospeed about this. There are several members that are trying to reverse-engineer the 4.3 & 4.4 ECUs so we can have something programmable by the end user.
Old Apr 12, 2005 | 11:28 PM
alecw81's Avatar
And I know several 10 second DSMs that would tell you otherwise...
Old Apr 20, 2005 | 06:52 PM
BlackT5's Avatar
...and DSMs use Motronic 4.3/4.4?
I cannot speak from experience, but people say it won't work on their Volvos. If it does indeed work for us then I will be very happy.
Old Jan 21, 2006 | 07:39 PM
ORIGINAL: alecw81
Not really, you do need a ECU upgrade. It will handle it much better.
denver005
Mar 12, 2011 09:59 PM
whitebox850
Mar 13, 2010 06:57 PM
S70_00
Apr 20, 2007 11:24 AM
HelgaTheS80
Dec 16, 2006 07:17 PM
S70driver
May 15, 2006 05:02 PM
