nitrous>?
Old Sep 12, 2007 | 01:57 PM
kcvolvo's Avatar
Default nitrous>?
just curious who has used the bottle on there turbo motors and what kind of out come did they have with it?
Old Sep 12, 2007 | 02:25 PM
Default RE: nitrous>?
A few people on another forum have used it and with good success.
However you must remember you need to know everything there is to know about Nitrous before you install it. Because one wrong move and BOOM.
Don't run more then a 30 shot to start out with.
Old Sep 12, 2007 | 03:03 PM
kcvolvo's Avatar
i have had a few vehicles with nitrous so i know how to use it properly i was just curious how much people were running and what kind of power they had made
Old Sep 12, 2007 | 03:08 PM
Not many people running it and you shouldn't run more then 30-35 shot. The internals cannot handle it.
Old Sep 12, 2007 | 03:38 PM
kcvolvo's Avatar
i will keep that in mind figured with being a turbo motor they would have better internals
Old Sep 12, 2007 | 04:05 PM
Well they have internals that can handle what it has and a little bit more.
However when you upgrade to Nitrous your in a whole different playing field.
I would seriously look into upgrade rods and pistons as well. Also run a wetshot.
Old Sep 12, 2007 | 04:17 PM
kcvolvo's Avatar
are most people running wet shots i know with my merkur it was reccomended running a dry shot with a turbo application
Old Sep 13, 2007 | 01:19 PM
ORIGINAL: kcvolvo
I believe a few on Volvospeed were using a wet shot. I could be wrong though, but if my memory serves me right it was a wet shot.
Old Sep 14, 2007 | 07:31 PM
gordon368's Avatar
How much money would it cost for me to add a nitrous system to my 2001 s80 t6?
Old Sep 14, 2007 | 10:19 PM
ORIGINAL: gordon368
I'm going to say at least $500 probably plus.
Because your going to want tuning for it. And your I wouldn't run more then a 35 shot unless you beef up your internals.
Old Sep 21, 2007 | 12:01 AM
boostedbrick's Avatar
Laughin gas. WHooooo Just up the boost on the little turbine and add a mathanol injection kit to cool the charge instead of spraying. Upgrade the intercooler and injectors, find some sort of piggy back system to run more fuel pressure if needed and have a grand ol time.
Old Oct 2, 2007 | 01:16 PM
jwheels54's Avatar
I actually plan on running n2o with mine but only as an intercooler bar i already have a wet kit lying around so im just gonna covert to the intercooler bar but i wouldn't run n2o in the motor with stock internals or even a stock clutch
Old Oct 2, 2007 | 08:48 PM
white out's Avatar
why? n2o is expensive, co2 is cheap and will cool the i/c more than enough.
+1 for everything that boostedbrick said.
Nick
Old Oct 3, 2007 | 09:36 AM
jwheels54's Avatar
co2 isn't that much cheaper if any go to a co2 refill see how much they charge last time i knew it was like 8 to 10 dollars to fill like a 3lb bottle it cost 35 to fill a 15lb n2o bottle
Old Oct 3, 2007 | 11:22 PM
I wouldnt waste 35 bucks throwing it into the wind though. If your gonnause nitrous, use nitrous.Dont spray it over the intercooler and waste it. If anything spray a 30-50 shot and put the purge behind the intercooler so it will spray on it. For everything else just up the boost. Im running 18psi on mine right now and pulls like a son of a bisquit. Thats a wagon too with no tune just a lot of work and a big *** turbo.
Old Oct 4, 2007 | 12:28 PM
white out's Avatar
ORIGINAL: jwheels54
To fill my 10lb bottle (keggerator) it is $15, I doubt it would be any more for a 15lb bottle.
Nick
Old Oct 8, 2007 | 05:31 PM
jwheels54's Avatar
well i know when i played paintball my 3lb bottle was like 8 bucks to refill but i have a 15lb bottle and everything to do the intercooler bar but the bar itself so i figured why not with a possible 15 to 20hp gain
brian.keith
Nov 8, 2011 05:43 PM
jony51999
Jul 31, 2009 02:06 PM
WhooFleuryScores
Jan 14, 2007 08:31 PM
volvo5
Oct 21, 2006 12:33 PM
L98Volvo
Sep 15, 2006 08:47 PM
