S80 T6 Intake...can't find one!!!
Old Oct 11, 2007 | 05:04 PM
otizzy's Avatar
Default S80 T6 Intake...can't find one!!!
Does anybody know where I can find an intake for my 99 S80 T6 2.8? I have done numerous searches online and have yet to find one. Thanks!!
Old Oct 11, 2007 | 10:31 PM
Default RE: S80 T6 Intake...can't find one!!!
1. Have you truly looked?
2. Have you even taken a look at these two threads?
https://volvoforums.com/m_38606/tm.htm
https://volvoforums.com/m_65537/tm.htm
3. I don't know but this seems like an intake system for the S80 models right here. Might be out of stock but at least it is an intake system for your car. http://www.vivaperformance.com/catal...roducts_id=101
You could check the internet by using GOOGLE to possibly find it elsewhere. Also it is not a direct fit, so you will have to make it fit. However it will fit if you try.
4. You could make a custom intake. Fab one up yourself.
Old Oct 11, 2007 | 10:55 PM
E_S80's Avatar
S70driver, that one from viva has been out of stock forever, and there is really nothing else available for the S80. The best thing is to make a custom one yourself.
You'd want to get a little bit of piping away from the MAF and then get a cone filter like K&N. You'd probably want a heat shield as well depending on where you live, to keep the air being sucked into the intake cool.
Old Oct 12, 2007 | 08:56 AM
ORIGINAL: E_S80
And like I said search GOOGLE as I am sure you can possibly find that intake elsewhere. I know it has been out of stock for a long time. You could also call Viva and ask if they can get one in for you too.
Old Oct 12, 2007 | 09:03 AM
http://www.bmcairfilters.com/infoCDA.asp
Find the one on there for 80mm and that is the one you should buy if you want that intake system.
Distributors: http://www.bmcairfilters.com/VisDistsArea.asp?IDArea=4
I'm sure if you call these places even if they are not in your area or even close to you, you can purchase it through them and they will ship it to you. If not try and get BMC CDA themself's to do so.
shur
Jun 22, 2015 03:20 PM
Brennan.Messick
Sep 19, 2011 03:06 PM
pete8475
Aug 10, 2009 10:31 AM
designstate
Jun 5, 2006 06:13 PM
