transmission fluid
Old Jul 27, 2005 | 03:58 PM
fast850r's Avatar
Default transmission fluid
OK. Another question. My 850 has 113,400 miles on it, and it runs great. I thought I might just change the tranny fluid and filter due to the mileage. I don't know if the previous owner had it changed. When I called my local delaer, they said they would have to look at the tag on the tranny to see what kind of fluid is in it. Then hook up the machine to flush it out. And it would cost between $200 - $900 Sounds awful high to me. Anyone have any thoughts?
Old Jul 27, 2005 | 05:08 PM
JimKW's Avatar
Default RE: transmission fluid
Search this forum or volvospeed.com and find out how to do it yourself. I have never changed or flushed the fluid in mine, but I hear it is a piece of cake. I don't believe they have filters. There is a drain plug to drain and fill, but flushing is different. You take a hose off the radiator and run the fluid out a couple quarts at a time until it runs out and looks like what is going in. I think it takes about 12 quarts to flush properly.
Old Jul 27, 2005 | 10:24 PM
ORIGINAL: JimKW
You got it that is the best way to do it.And yes They have no filter.
Old Jul 28, 2005 | 10:52 AM
JimKW's Avatar
See Tech, I'm learning from reading all the stuff you tell people.
Old Jul 28, 2005 | 01:16 PM
reg's Avatar
reg
What is interesting is that a dealer would quote a price up to $900.00!!!!!!!!!!!!!!! I can not imagine what that would encompass. I believe the Volvo dealer charged me around $125.00 this early spring for a flush...................
Old Jul 28, 2005 | 02:02 PM
fast850r's Avatar
REG - Thanks for that. I can't figure for the life of me what would cost $900! He said by looking at the tag on the tranny, would tell them what fluid is in it. Isn't fluid, fluid? If he said $125, I would have made an appointment.
Old Jul 28, 2005 | 03:11 PM
reg's Avatar
reg
I believe...............won't swear by it..................that the fluid the dealer put in was General Motors. The dealer sells G.M. , Volvo, GMC, and Mazda. You are right...................fluid is fluid and there are but a few used and none of them are exotic. Type A, Type F, and "the new stuff"................which cost me appx. $125.00 for a flush. In fact, it is so inexpensive for this service, I do it every 20,000 miles on all my autos! If you are strapped for cash, it is as Jim says...............a do-it-yourself-project.
Old Jul 29, 2005 | 12:34 AM
I believe the 850 is just ATF.The newer cars use 2 different fluids depending on the trans.The 4-speed uses one and the 3-speed uses another fluid.
EDIT: My cheater book says dextron III/ mercon fluid.Which is the normal ATF.
AustinPower
Nov 11, 2008 07:43 AM
flyingo
Apr 27, 2005 07:19 PM
94volvo850
Feb 18, 2005 06:49 PM
