rattling noise from front end?!?
Old Mar 13, 2009 | 12:00 PM
rupert77's Avatar
Default rattling noise from front end?!?
I noticed it gradually getting worse, firstly it sounded like a bed's mattres whenever you would get off it and then gradually the noise has got worse it now sounds like as if there is a loose water bottle even though it's not but it is an echoing rattle especially on rough ground going slow. My friend says it's coming from the left side but i think it's coming from both sides as i have driven over rough ground on both tyres and the sound comes on both. Does anyone have any ideas maybe it's a shock or something worn i dont know as i never had to replace these before in any of my cars! Any ideas?
Old Mar 13, 2009 | 08:34 PM
I would check sway bar and end links. Also the top strut bearing plate.
Old Mar 14, 2009 | 04:04 AM
rupert77's Avatar
thanks tech going to bring it down to my mechanic he has a lift so it will be easier to get looking at it. Also forgot to say that when i take off anyway hard and the wheels start to spin a bit there is alot of knocking around under the car also in the same area!?!
Old Mar 14, 2009 | 06:27 AM
v70 2.4t's Avatar
might be an Engine mount ??
good luck
v70 2.4t
Old Mar 14, 2009 | 12:00 PM
rupert77's Avatar
Yeah i thought something like that to but have been with mechanic and outcome is broken drop link, have to go shopping around now it would be better to get 2 and replace both maybe?
Old Mar 14, 2009 | 09:23 PM
Yes I would do both this way in a month the other one does not break.
Old Nov 20, 2009 | 03:11 PM
bpmarkham's Avatar
I've got 2 sway bar links on the way so here's my question. In order to replace these do you just loosen a nut on the back side of the link bolt? The bolts on the link are throwing me off. Do you need a special tool to hold those in place or do they not move? Where does the hex tool come in?
Old Nov 20, 2009 | 07:06 PM
Do you have air tools?
If not then some have slots on the back that a 17MM wrench will fit onto.
Others you need a allen or torxes bit to hold the center when you tighten the nut.
Yes just loosen and remove the nuts.
Old Nov 23, 2009 | 04:27 PM
bpmarkham's Avatar
Thanks tech. No air tools here. I'll figure it out more when the parts get here and I get a chance to swap them out.
Old Jun 17, 2011 | 11:30 PM
revray's Avatar
just did mine - very easy used a 15 mm wrench with a T30 hex, but I still had rattle so next is the strut bearing.
bigkey
Oct 2, 2015 06:03 AM
Wing0
Dec 13, 2013 02:39 PM
s40volvo
Jun 29, 2011 12:20 PM
MattS77
Jan 20, 2008 05:26 PM
Roge
Sep 8, 2007 11:19 AM
