2001 Volvo S40 Hard to Start Please Help...
Old Mar 19, 2009 | 02:16 PM
BSCrouse's Avatar
Question 2001 Volvo S40 Hard to Start Please Help...
Hello everyone. I need some assistance. I purchased a 2001 Volvo S40 and am having some minor trouble. In the mornings when cold, it simply will not start without pumping the accelerator lightly and then I have to hold it at about 3500 rpm for 3 minutes before it will run. It also smells very rich when this happens. After that, it runs and starts fine for the most part for the rest of the day.
I have replaced the following items:
MAS Air Flow Meter (it was reading low voltage)
Fuel Pressure Regulator
Coolant Temperature Sensor
...all parts from the local Volvo dealer with genuine Volvo Parts.
Not to mention I have also checked the car for a possible vacuum leak and have uncovered nothing. Anyone's assistance with this situation would be great.
I love this little car and am about to throw in the towel.
Thank you,
New Volvo Owner
Old Mar 19, 2009 | 02:56 PM
cuishy's Avatar
Default Look Into
A new crankswitch.. Mine did the same thing until i put in the crankswitch and now it starts right up.
Old Mar 25, 2009 | 06:23 AM
BSCrouse's Avatar
Thank you for your advise. It turns out that after I took off the idle air control valve and cleaned it out, then did a complete carbon cleaning (professional fuel injection service), the car runs perfect!
Old Oct 17, 2012 | 09:39 PM
TheRealOneMCD's Avatar
Default I have a similar problem
Hi there,
I also bought a Volvo S40 2001 and it was working very fine at first.
But then it started to stalls after the car spent to much time not running (24+hrs) when I try to start it. Ive changed the battery. The oil and battery check light are turned on when it happens and I have to push on the accelerator + brakes to put it on idle.
I dont know what to do, can you help?
Thanks.
Old Oct 17, 2012 | 10:11 PM
Hudini's Avatar
Either the Idle Air Control motor or the Fuel Pressure Regulator. I'd suggest cleaning the IAC motor first before replacing. Also, check the fuel pressure first before buying a new regulator.
DecalService
Dec 4, 2019 10:52 PM
hatsy
Jan 20, 2014 05:52 PM
icthus
May 29, 2012 12:30 AM
daver80
Jul 13, 2009 10:19 PM
jerryman
May 23, 2006 01:19 AM
