Catalytic Convertor on fire
Old Sep 30, 2005 | 09:28 AM
POKDUB's Avatar
Default Catalytic Convertor on fire
I have a 1996 V40.
The car engine began to stutter yesterday, like one cylinder was not firing.
At the same time an immense heat was coming off the Catalytic Convertor, so much so, that smoke begain to come into the cabin.
Does anyone have any suggestions as to way the Cat is burning so badly.
At cold start the engine works fine, after about 2 miles she begins to die and the heat builds up.
Rgds
Peter
Old Sep 30, 2005 | 09:18 PM
Default RE: Catalytic Convertor on fire
The cat is clogged and needs to be replaced.
Old Oct 3, 2005 | 11:23 AM
POKDUB's Avatar
Tks Tech. I have discovered that the coil unit firing cylinders 2&3 is faulty.
After the car warms up, it stopped firing on cyl 2.
Pump raw fuel into the Cat and this caused the immense heat.
I am getting a new coil unit tomorrow and will probably have to get a new Cat as well.
72Demon
1998-2000 model year V70
Dec 6, 2012 02:02 PM
mason.marino
Jul 5, 2009 07:36 PM
tbenner
Jun 13, 2007 09:22 PM
RazorT
Oct 27, 2005 06:48 PM
POKDUB
Oct 3, 2005 11:20 AM
