how to remove 5 spd shifter knob?
Old 05-18-2009, 02:04 PM
mark850t's Avatar
Default how to remove 5 spd shifter ****?
hey guys i was just curious how to remove the shifter **** to replace it . i noticed that it doesnt unscrew like most other cars . how do you take it off otherwise?
Old 05-18-2009, 04:50 PM
JimKW's Avatar
I think they just pull off, but not really sure. Did you look up under it to see if there is some kind of clamp or c ring?
Old 05-18-2009, 11:38 PM
850tony's Avatar
Replacing gear **** and gaiter
To remove gear shift ****
-Cut off the outer casing on the **** with a knife
-Remove inner sleeve using pincers so the locking groove is exposed.
-Remove ****.
To remove gear shift gaiter
-Remove cover under parking brake lever
-Detach gear shift gaiter from center console by pressing on rear of the gaiter on the snap fasterners from below via the hole under the parking brake.
-Pull off gaiter from the gear shift.
Old 05-19-2009, 11:32 AM
mark850t's Avatar
hey thanks 850 tony . is there anyway to remove it with out cutting the stock ****?
Old 05-19-2009, 11:38 AM
850tony's Avatar
not sure. what i would try would be twisting it off with a channel locks or something which would just bend that clip out a little bit.
i personally think its a poor design on multiple levels.
Old 05-22-2009, 06:46 PM
mark850t's Avatar
yeah me to but thanks tony i will try something and let everyone know .
Old 05-22-2009, 09:10 PM
850tony's Avatar
please do because i would like to take mine off to haha
Old 05-27-2009, 12:18 PM
mark850t's Avatar
well good news guys. after a day of trying and getting pissed off i got it off without cutting the leather. i used a small flat head screw driver and pryed under the **** where the c clip is . if you pry it far enough away from the shifter you can pull the handle out. it was still hard to pull out but i got it off in one piece.
Old 05-27-2009, 10:18 PM
850tony's Avatar
nice! i will have to give that a try. very nice!
Old 09-29-2011, 02:15 PM
Lulumike's Avatar
Dear Tony et al.,
thanks for all that. One diagram showed that it was a screw on. (1994 850 5 speed) Was that the case with either of you?
Old 09-29-2011, 11:08 PM
Lulumike's Avatar
Mark, is the c clip plastic? And there are two of them? How do you take it off without breaking the c clip? (I suppose it doesn't matter since those should be easily replaceable--although you never know with a Volvo.) Also, the **** pulls straight out? No unscrewing? Thanks.
readvl
04-15-2015 10:01 AM
scouttyboy
07-08-2008 05:35 PM
map1470
06-20-2007 10:47 PM
bambam
02-15-2006 04:42 PM
Betchins
11-21-2005 01:38 PM
Quick Reply: how to remove 5 spd shifter knob?
