2000 C70 HT Coupe - Suspension Squeak
Old May 22, 2009 | 02:24 PM
elav's Avatar
Default 2000 C70 HT Coupe - Suspension Squeak
My car has just developed a front passenger-side suspension squeak a couple of days ago and wondering where to start looking. Squeak happens at low speeds with small bumps in the road.
I've replaced the spring seats, strut bearings, sway bar endlinks 3 weeks back (and no squeaks at that time) and last week I had new tires put on (mounted and balanced), front brake rotors/pads replaced, tie rods replaced and an alignment. A few days after the tires/brakes/tie rods/alignment I developed a squeak. I had the tires/brakes/tie rods/alignment done at a place where auto-crossers drive for a couple of hours to get their cars done here, so I know it is a good shop and they will stand behind their work.
I'm thinking that perhaps the squeaking is coming from the springs not bing seated correctly. Thoughts?
Old May 22, 2009 | 03:14 PM
mick1232's Avatar
Bounce on the front end and listen with the bonnet up test each side if you heart nothing check ya top engine torque mount ive just replaced mine it was like a frog under bonnet when i let off the clutch and over minor uneven roads .I also would check ya subframe bushes mine on the back were in a bad state suppose to be a problem with our models and others from 98 to 01
Old May 22, 2009 | 06:35 PM
elav's Avatar
Good point. I just replaced my top engine torque mount too. If that is the issue, any way to quiet this down?
Old May 22, 2009 | 06:44 PM
mick1232's Avatar
Do you have the older type the round bush with mount housing round at top or the new square bush ? I replaced mine a few weeks ago and its cured the noise but i also replaced the same mount about 8 months ago and after installing it i still had the sqeaking noise so i stuffed the housing with a hot glue gun it stopped the bush moving in the housing but i did experience vibrations by doin this
Old Jun 15, 2009 | 01:59 AM
guy_014's Avatar
Hey Mick,
When I bounce up and down on the front end, I can hear it squeak, do you know what part it is then? Its driving me mental at the moment!
Thanks for your help mate!
Old Jun 15, 2009 | 12:35 PM
mick1232's Avatar
can you state if the squeak is at high level or dont ya quite know ? im thinking if ya top rubber shocker bush mounting has torn llok at ya shocker under ya bonnet and you will c if the shocker stem has pulled through alittle .Could also be ya tie bar links what go from ya strut to anti roll bar m8
Old Jun 15, 2009 | 05:10 PM
guy_014's Avatar
hey mick, thanks for your reply and help, your a legend!
yeah the squeak is very high, i took a photo for you. is it easy to fix? you know where i can get the part from at all?
thanks again for your help mate, appreciate it!
Guy.
Old Jun 16, 2009 | 02:58 AM
mick1232's Avatar
Hi m8, you have to take ya shocker off and strip it down were abouts are you and il find ya the part m8
Old Jun 16, 2009 | 04:02 AM
guy_014's Avatar
Hi again mick,
Is this the part in question? - http://www.fcpgroton.com/product-exe...ategory_id/181
Old Jun 16, 2009 | 05:42 AM
mick1232's Avatar
That is the 1 m8 but please note its possible to be ya anti roll bar link bars squeaks are difficult to pin point
Old Jun 16, 2009 | 10:07 PM
guy_014's Avatar
Thanks again Mick, where is that located? is it hard to fix also?
Cheers!
Old Jun 17, 2009 | 12:37 PM
mick1232's Avatar
link bar to the left side of shocker
Old Jun 17, 2009 | 10:10 PM
guy_014's Avatar
thanks so much mick your a great help.
also not a fix, but the squeak was driving me insane, i sprayed some wd40 on the top shock bushing and it quietened down entirely. will have to change the bushing when i have time.
Cheers!
AdoCorradoVr6
Jun 30, 2012 09:51 PM
AdoCorradoVr6
May 13, 2012 04:37 PM
schoolboy
Nov 9, 2011 04:17 PM
oldacura
Apr 20, 2010 09:52 AM
elav
Apr 24, 2009 10:01 PM
