Driver and passanger air vent in center consle`
Old Sep 9, 2009 | 07:45 AM
04XC90T6AWD's Avatar
Default Driver and passanger air vent in center consle`
MY air vents the passanger and driver air vents that is in the center console have broken. My dealer said they'd have to pull out the entire dash in order to replace that well i decided to get a second optionion from myself i have been able to pull it out without a problem as a matter of fact it just pops right on. one could proabably do it with the most primitive tools. That said i need to order the peice its the peice that has the air vents and the 4 way flasher button on it does anyone know where i can order this from. Also i want to get some coustom floor mats like i got for my two S80's that said S80 on the all of the mats does anyone know where i can get those as well. I would like to be able to order the air vent on line but will go to the nearest place in CT for the mats. You can eiter email me pm or leave a message here with an answer to my questions. Thank you in advance for your response and your help towards resolving my problem
Old Sep 9, 2009 | 09:13 AM
can anybody give me some help?
Old Sep 23, 2009 | 07:36 AM
gantid's Avatar
Default how to remove the a/c vent cover
Hi,
I need to remove the vent cover as one of the slats of the vent cover is broken and looks like the metal strip holding the slats has been dislodged. How hard is it to remove the vent cover? Do you have to press down any clasps to pop it open?
thanks
D. D.
Old Oct 21, 2009 | 06:59 AM
mikeandjenn99's Avatar
I'd like this info too if anybody cares to comment.
Old Oct 21, 2009 | 07:31 AM
gantid, All you really need is a flat head screw driver to remove the vent cluster with the hazard button just carefully wedge a flat-head into the side and work it up and it should pop off after you get it off its pretty easy to see how to take it apart and put it back together as to getting another peice i have no idea as to where because of course no one has relpied or told us so i have made a temporary fix for the time being with some zip ties. Also while i have everyones attention did you know about the 2004 xc90 Transmission problems. Apparently one of the enginners decided to go cheap and put in a GM transmission thats only rated for a 180HP engine on a 240HP engine long story short the transmissions go. If yours should go volvo will personally pick up the bill if you take it to a volvo dealer. This is even if you are out of your wareenty
Old Oct 23, 2009 | 07:11 AM
gantid's Avatar
Thank you very much. I will give it a shot.
D. D.
Old Oct 23, 2009 | 01:11 PM
lynnebucher's Avatar
Water leaks!! I have an '04 XC90 with over 114,000 mostly trouble-free miles, but a couple of significant downpours have caused water to collect in the front passenger well, and now the car sloshes—water in the right rocker panel, it sounds like. The water seems to leak down the a-pillar. Has anybody experienced this, and how do you get the water out?
Old Nov 9, 2009 | 11:49 PM
m1964's Avatar
clean sun roof drains -use search how to
Old Nov 10, 2009 | 09:08 AM
yeah its proabably your sunroof drains since i have some peoples attnetion sometimes i like using geartronic. I shift around like 4,000 rpms for gear one cause then engine sounds like its going out of gear around that time im not sure if im shifting at the right time can somoene tell me what rpm to shift at for each gear? I have driven manual but my old manual transmission car was a real deal manual and it was a 1979 oldsmobile cutlass calis
Old Aug 7, 2012 | 05:03 PM
IncomeMotion's Avatar
It is critical that you don't break the retainer clips inside. Follow this great pictorial http://www.justanswer.com/volvo/59dbq-volvo-xc90-3-2-remove-dash-center-air-vent-assembly.html
Old Aug 7, 2012 | 08:08 PM
schumicat's Avatar
no one is going to sell something like that new except the dealer. for used try ebay or a junkyard that specializes in swedish cars (there are a few in the US that will ship).
koksalan
Jun 5, 2014 02:14 PM
jvangun
Apr 10, 2010 05:07 AM
mrbeavin
Apr 15, 2008 02:06 PM
spelton
Jul 23, 2006 01:17 AM
