99 S80 Coolant Loss Diagnose
Old Oct 10, 2009 | 07:05 PM
stojakovic's Avatar
Default 99 S80 Coolant Loss Diagnose
My friend are leaving US, and he would trash the S80 as it has a blown head gasket. I told him I will take care of it. Now I am the owner of it.
Head gasket symptom: Coolant loss due to water came out of tailpipe. Coolant tank smells gas like. Milky engine oil. Miss fire.
I am now trying to use gasket sealer to temporarily fix it. When I was flushing the cooling system, I found the driver side carpet was wet: heater core leakage.
Moreover, the cooling system seems to be under high pressure, the upper radiator hose was hardly to squeeze when engine was running. Is this normal?
I have a 97 850 and been working on it a lot. S80 is a little new to me. Is it similar to fix the heater core as 850?
Old Oct 10, 2009 | 08:08 PM
The S80 is a little harder for the heater core.
2 things I can think of
1. Thermostat is stuck.
2. The plastic impellers on the water pump broke and there is no circulation.
Old Oct 10, 2009 | 09:42 PM
stojakovic's Avatar
There is circulation I think. The upper radiator hose can get hot when engine is in normal temp. The water is warm when I drain it after it got normal temp. This also indicates that the thermostat is good.
Old Oct 10, 2009 | 09:50 PM
That might only be heat from the motor. It is just a thought I have seen a few broken water pumps and thermostats cause the exact same issue.
Old Oct 10, 2009 | 09:58 PM
stojakovic's Avatar
Yes, I hope if it is due to these things. They are easy to fix!
Old Oct 10, 2009 | 09:59 PM
They are not that bad.
Old Oct 11, 2009 | 11:31 AM
stojakovic's Avatar
Progress:
Check the spark plug holes. I can see water in No.4. Oil filled No.6.
For heater core, I just bypass it right now. Cut the hoses and connect them.
Tech, how to disable fuel injector in S80? Just unplug the attached electrical switches?
Old Oct 11, 2009 | 05:11 PM
Why do you wan them to not work?
Old Oct 11, 2009 | 07:05 PM
stojakovic's Avatar
While I checked the spark plugs, I found water in No.4 cylinder and oil in No.6.
Disable the No.4 injector will allow the gasket/block sealer to work. Let it fire will keep sealer from passing through the holes due to combustion gas pressure.
Am I right?
Old Oct 11, 2009 | 07:26 PM
Not sure I do not use that stuff. You can just unplug the injector if you want.
Old Oct 11, 2009 | 08:36 PM
Julesisjazzy's Avatar
Where can I find replacement hoses that go to the heater core?
markp5
Nov 3, 2012 08:47 PM
mcgiiver
Jun 14, 2010 06:35 PM
mhphoto
Aug 8, 2007 01:44 AM
arlovarri
Oct 17, 2006 07:03 PM
