240 DL Front Wheel Bearing Replacement
Old Oct 28, 2009 | 10:04 AM
rangerjoe0202's Avatar
Default 240 DL Front Wheel Bearing Replacement
Can anyone post a link or instructions for replaceing front wheel bearings on a 240 DL.
I have some side to side play on the drivers side while the tire is on the ground.
Does this indicate that the Wheel Bearings are bad, can I just replace the outer bearings or do I need to replace the Bearing Hub
Thanks in advance.
Old Oct 29, 2009 | 06:47 AM
act1292's Avatar
This could be caused by various problems. However, it should be fairly easy to diagnose. First check for play by placing your hands at 9 & 3 oclock. Then check for play at 12 & 6 oclock (need to be jacked up for this).
If you have play at 9 & 3 oclock but not at 12 & 6, then your problem most likely is your tie rod ends.
If you have play at 12 & 6 oclock but not 9 & 3, then your problem is most likely ball joints.
If you have play at both, then it could be your wheel bearings or both of the above.
oovvutt
Sep 22, 2014 12:50 PM
oragex
Jan 4, 2014 01:26 PM
rspi
May 21, 2013 10:15 PM
swede850T
Nov 4, 2005 09:29 PM
