T5r Motronic schematic, please!
Old Nov 3, 2009 | 10:20 AM
Cameronian's Avatar
Default T5r Motronic schematic, please!
I have a hiccupping T5r and it's getting worse, even though we've done all of the easy stuff.
My mechanic wants to check out all of the parameters for the contacts on the Motronic box but cannot find the system schematic and info that he needs. The box is Bosch number 0 261 203 626. Every tech sheet that he has located has three rows of 10 contacts each for the "B" connector on the bottom of the box whereas our box has three rows of 15 contacts each for the "B" connector. Where can I find or download the correct system schematic and values so he can check that each contact is doing what it should, please?
Your help will be very much appreciated.
Old Nov 3, 2009 | 10:26 AM
fcpgroton's Avatar
Former Sponsor
What is the issue you are having with your Volvo?
Old Nov 3, 2009 | 11:06 AM
Cameronian's Avatar
It's a very long story to do with rough rich running and severe hiccupping which originally occurred when cold but which now happens all of the time. We've had a variety of codes, including the usual ones. We've replaced plugs, leads, air mass meter, throttle position sensor, lambda sensor, coil, injectors, distributor cap and lots of pipes and tubes. This has been going on for months. Now we want to check the outputs of all contacts on the box but can't get the necessary data.
Old Nov 4, 2009 | 04:25 AM
Cameronian's Avatar
Oh dear, it's a bit subdued here! Will I be able to get the information I need or will I have to explain better what I want?
mikeri
Jun 1, 2020 06:32 PM
detrock
Dec 30, 2007 10:30 AM
jjr_740
Aug 26, 2007 12:32 PM
vovo760turbo
Jun 20, 2005 11:18 AM
slotmachines
Feb 13, 2005 01:54 PM
