Considering an 850, need help
Old Nov 8, 2009 | 05:45 PM
ZJcory's Avatar
Default Considering an 850, need help
Hey guys and gals,
I went and checked out an 850 today and I'm seriously considering buying it within the next day or so but it had a couple of issues that I'd like to run by you guys and get your opinions. It's a '95 850 n/a 5 speed with 160k on the clock. It drove fine, although it has a check engine light on and the transmission won't shift into first until you almost come to a complete stop. Is this a worn out synchro or something more serious? He also mentioned that the heat is warm, but not really hot.
Old Nov 8, 2009 | 05:52 PM
I'm not too much of a pro on transmissions.....yet. But how much is he asking for the car if it has tranny problems? Because unless you can do it yourself, it would be pretty expensive to fix.
Old Nov 8, 2009 | 06:01 PM
ZJcory's Avatar
He's asking 1000, and the car is extremely clean and drives very well except for that one issue, and a check engine light. Other than that the clutch and tranny feel fine.
Old Nov 8, 2009 | 06:32 PM
Hm, That's not too bad. I would wait for someone who knows a little more about tranny problems. But if you can't do it yourself, a shop would charge a lot to do it.
Old Nov 8, 2009 | 06:47 PM
vpatrol's Avatar
I would try and get the code read to and see why there is a check engine light.
Old Nov 8, 2009 | 06:52 PM
Somthngfrce's Avatar
Sounds like a good deal.....but I would ask him/her to have the ecu scanned and post the code(s) on here for the check engine light. We can look those up for u. Might be a synchro, but could be something else. 5 speed is normally easier and cheaper to replace than an automatic.
Old Nov 8, 2009 | 09:09 PM
ZJcory's Avatar
He mentioned something about taking it somewhere to have the code read, but it's obd 1 or something? He said the light's been on for a while and it passed inspection while it was on. I need to decide on this by tomorrow so I'm more worried about the transmission problem.
Old Nov 8, 2009 | 09:15 PM
Aftermidnight's Avatar
95's are OBDII.
Personally I would wait for a turbo.
Good-luck!
Old Nov 8, 2009 | 09:22 PM
Uh, what a dum dum. 94-95 850s were OBDII. Take out the coin slot holder thinger. There's an OBDII port underneath it.
Old Nov 8, 2009 | 09:38 PM
Here is a link to our Buyer's Guide.
I had a Manzda that did not like going into 1st unless the car was at a stand still. It did not bother me much, just drop in it 2nd and move on. It never gave me any problem.
Get the CEL codes. It may be several of them. But $1,000 for a car that runs... hard to beat that.
Old Nov 8, 2009 | 10:00 PM
Especially if it's a Volvo
Old Nov 9, 2009 | 12:24 AM
Carrots's Avatar
Not ALL '94s are OBD-II. My current project '94 isn't... and it's even a late- production '94. 94 is an oddball year.
As for getting a running volvo for $1000... I got my '94 for $300, and drove it home. Of course, it has 250,000 miles, needs a PCV system, timing belt, spring seats, an A/C evaporator, a bunch of engine seals, oil pan o- rings... basically, it's a Volvo 850. But still... it's a driveable Volvo that cost me next to nothing
Old Nov 9, 2009 | 01:29 PM
When I got my 850 it had all of those things needed as well. It does not have the miles nor oil leaks but almost every 850 you buy will need a timing belt, pcv system, and some other things.
Old Nov 9, 2009 | 08:43 PM
Carrots's Avatar
Oh, I know that... I repair European cars. I was just kind of making a joke about it needing what it does. I've done all of those things on a number of 850s and 70 series. If I hadn't, I wouldn't have bought that 850. I got it to fix up and sell for fun and a little profit. Right now, as we speak, I'm examining the ABS module to see it it needs any resoldering
Ahmed
Oct 9, 2012 11:51 PM
Veekay
Feb 18, 2009 10:55 PM
HonestTodd
Jun 7, 2007 06:44 PM
92Typhoon
Jun 3, 2007 01:50 PM
