Considering purchasing a C70, but need advice.
Old Jan 29, 2009 | 12:03 PM
Veekay's Avatar
Default Considering purchasing a C70, but need advice.
My 2000 Ford Taurus may be on its last legs. I inherited it as a company car and it's done very well. 150,000 miles with all original everything. Other than changing its oil every 3,000 miles (almost religiously) I've spent very little in any type of repair.
I've always wanted a convertible, and plan to buy one when the Taurus finally dies, and the C70 is on the top of my list.
My question is how dependable are the Volvo Convertibles? Am I buying a car that I probably won't have to worry about, or do they start causing minor problems after awhile. I don't usually follow the reommended maintenance schedule, I just make sure the oil is always changed. Is a Volvo one of those cars that really require the services?
Any insight would be helpful. Thank you.
Thank you.
Old Jan 29, 2009 | 02:15 PM
What year are you looking for?
They do have problems. I would say a little more than the average.
Old Jan 30, 2009 | 09:58 AM
MoneypitC70's Avatar
If you are looking for a 98-05 model make sure it has a service history with records! ALL 5 cars I inspected had worn front end parts and they are expensive to repair...unless you do it yourself.
Old Feb 13, 2009 | 01:37 PM
magic's Avatar
I am looking to buy a 2000 C70 convertible. How are these cars and do they give a lot of problems? Is there anything special that I have to look apart from the front ends. And how expensive is to replace the front ends?
Thanks
Old Feb 15, 2009 | 09:02 AM
FredMc's Avatar
Thanks
go to parts places online.
fcpgroton
ipdusa
etc and look up parts.
Generally after 7 years the whole front end is crap.
Look at 1200 wholesale parts at a min.
wheel hubs
tie rods
bushings
control arms
shock mounts
shocks
CV joints
and then the engine mounts, top and bottom, trans mount, and then internal engine components like timing belts, serp belts, tensioners.
All told if no service has been done in 7 years then count on another 1500 in parts for non front end related issues. If you are handy then great, if not look at doubling that for labor.
Old Feb 15, 2009 | 01:32 PM
magic's Avatar
Thanks for the info.
Old Feb 18, 2009 | 10:55 PM
kjn's Avatar
kjn
Default Regarding Your interest in 2000 C70
Hi, I am new and plan to list the car elsewhere on the forum. I have had for 5 years, a red C70, 57,000 miles with one full year extended warranty. If you are looking to buy, we should talk.
espo13
Aug 26, 2015 08:10 AM
Grip Grip
Nov 3, 2014 12:24 AM
MrJARichard
Jun 15, 2010 06:24 PM
midqa
Jun 20, 2008 12:50 PM
92Typhoon
Jun 3, 2007 01:50 PM
