power steering
Old Nov 16, 2009 | 03:15 PM
cheesenacho's Avatar
Default power steering
in a 94 850 when looking into the fluid reservoir should it be swirling around inside ?
Old Nov 16, 2009 | 05:19 PM
I don't know, are there fish in there?
Old Nov 16, 2009 | 05:21 PM
^ ahahahaha.
I believe if the car is running and you look inside there should be some movement.
Old Nov 17, 2009 | 09:41 AM
fcpgroton's Avatar
Former Sponsor
Yes, there should be some movement as the fluid is pumped around.
Old Nov 17, 2009 | 12:30 PM
i cant figure it out, the fish died. i thought they would help. seriously though im trying to find the cause of a sound like a loose belt coming from the steering pump and its not loose and there is no problem with the steering
Old Nov 17, 2009 | 01:53 PM
Back to the good old rule, don't fix what aint broke.
I think I can remember someone saying that they put bar soap on the belt to stop it from squeeling.
The pump may be going bad, the fluid maybe can use replacement, not sure. If you figure it out, please post back as to what you did to solve it.
al_ngl
Nov 23, 2011 12:06 AM
2002v70
Oct 17, 2009 06:31 PM
nehopsa
Jun 24, 2008 11:20 AM
intence
Mar 3, 2008 08:40 PM
katiejoyful
Dec 12, 2007 04:49 PM
