winter/wet selector button
Old Dec 7, 2005 | 09:10 AM
charlesbattaglia's Avatar
Default winter/wet selector button
The button does not engage. I realize the transmission must be in D. The diode light does not come on and the dash display does not change from D to W. Costly repair? Can I drive it without the winter/wet mode available? TY for assistance.
Old Dec 7, 2005 | 10:07 AM
Default RE: winter/wet selector button
When you put it into winter mode an arrow should lite on the dash. But it is only used in the snow/ice. It makes the car start in 3rd gear for less slippage.
If it isn't working and the car is shifting ok then you can drive it no problem.
Old Dec 8, 2005 | 06:53 AM
ty for the quick answer...good to know I don't have to spend dough to fix something. The "W" button seems frozen, as it does not move at all when pressed. Does it need a shot of silicone spray?
Old Dec 8, 2005 | 11:56 PM
You can try that and see if it works.
schmuecker
May 19, 2011 06:45 PM
Retsto
Jun 4, 2010 08:28 PM
fluidcognition
May 19, 2009 10:20 AM
Indigo Eve
Dec 18, 2008 09:58 PM
