Flashing [Mode "Wet/Winter" engaged] warning lamp
Old May 17, 2009 | 01:19 AM
fluidcognition's Avatar
Default Flashing [Mode "Wet/Winter" engaged] warning lamp
Hello,
The [Mode "W" engaged] warning lamp has been flashing intermittently for the last several months (it's shaped like an upward facing, orange arrow). When it does, my transmission acts funny. Sometimes it takes a very long time to accelerate. Sometimes, it barely accelerates at all. Today, it died while trying to accelerate.
My volvo manual says:
"The lamp will light up when the Winter/Wet starting mode isn engaged or if gears '3' or 'L' are selected.
If the warning lamp begins to flash, this means that there is a fault in the automatic gearbox. Contact Your Volvo retailer."
I have no intention of contacting my Volvo retailer, unless absolutely necessary. So, my questions are:
1. Could there be any other reasons why this indicator lamp would flash?
2. How should I go about finding and repairing a fault in the automatic gearbox?
As always, any help is much appreciated.
Thanks!
Old May 17, 2009 | 11:56 AM
robrike's Avatar
Your best bet would be to get the codes pulled for it. If it is a 93-95 model there is a way to do it yourself under the hood with the diagnostic box by the passenger headlight. There is a thread on her somewhere. If 96 or 97 you have to have them read with a scanner. Port is under the coin tray in the center of dash console. It could be something fairly simple like the PNP switch which tells the transmission which position the gear selector is in and other good stuff like that. That switch is about $100 and under the battery tray area on top of the transmission.
I would get it looked at ASAP. It is not good to drive it like that with it starting in 3rd gear for too long. I am guessing it resets itself sometimes and goes back to normal operation?
Rob
Old May 18, 2009 | 04:47 PM
Yes, you're right. It resets itself, usually if I turn off the ignition, and then restart the car. The problem has been manifesting more frequently, however, which is what has me concerned. It used to show up once every several weeks, now it shows up probably at least once a week.
Old May 18, 2009 | 09:02 PM
Johnny Mullet's Avatar
What year is it? Like rorike said, it could be the PNP switch.
Old May 19, 2009 | 10:20 AM
bestharry's Avatar
Is the oil level in transmission up to the mark?
john gill
2001-2013 model year XC70
Feb 9, 2015 04:33 PM
JKas
Nov 27, 2014 09:46 AM
hu5ker555
Jan 3, 2011 04:21 PM
Goat
Mar 27, 2010 02:16 AM
markmac
Jun 19, 2009 07:43 AM
