95 850 Heater Core bypass
Old Mar 16, 2010 | 05:02 PM
Twill08's Avatar
Default 95 850 Heater Core bypass
My heater core is shot, I would like to bypass it for the summer.
I was going to remove the junk core and make a loop with some heater hose off the existing lines. What is the size line do I need?
Or is there a different way?
Old Mar 16, 2010 | 07:53 PM
james_caza's Avatar
Look in your engine bay, drivers side above turbo. You will see two lines side by side running through the firewall. I believe the lines are around 3/4". Disconnect both hoses and attach them together and clamp them good. Very simple procedure.
Gluck
Old Mar 16, 2010 | 11:09 PM
gdog's Avatar
When you do get around to replacing it, go with OEM part; fcp has a good deal on them...
http://www.fcpgroton.com/product-exe...50+Heater+Core
Old Mar 16, 2010 | 11:50 PM
boxpin's Avatar
I did this for a short time. I used a spare hose from the second 850 I had, cut the end off and looped it back to the inlet on the engine. From one outlet to the other outlet. I used the long hose. If your not going or able to cut your hose then follow James_caza's advice.
Lima850
Jan 13, 2015 01:53 PM
ycartf
May 6, 2013 11:19 AM
s80turbo
Apr 24, 2011 06:31 PM
razak-ms
Apr 25, 2010 07:05 AM
