correct way to bypass the heater core matrix
Old Mar 31, 2010 | 09:56 AM
razak-ms's Avatar
Default correct way to bypass the heater core matrix
My heater core is leaking lately, since i am living in the tropical i do not require the heater system in my car. The question is, what is the correcy way to bypass the heater core matrix permenantly. It is by using 2 end caps to close the two points on the engine side or by joining the 2 points by using a hose. In my opinion by using the bypass hose is not good idea because we are injecting back the hot coolant into the engine thus bypassing the radiator. Need opinion on this issue. Thank you.
Old Apr 24, 2010 | 02:20 PM
araminta's Avatar
Default correct way to by-pass heater core matrix
Hi,
We have same problem, can you tell me if you had any success?
thanks
Old Apr 24, 2010 | 09:26 PM
razak-ms's Avatar
To araminta
I tried to use radiator hose end caps at the 2 point on the engine side but one of them burst because of high coolant preessure. Right now I am using back the loop but with a valve at the centre of the loop, i.e cut the loop at the middle and installed a valve. To prevent hot coolant from going back the engine the valve needs to be closed all the time. So far it has worked well till now
Old Apr 25, 2010 | 07:05 AM
araminta's Avatar
Smile correct way to by-pass heater core matrix
Hi, thanks for replying. Tried the hose method. Will let you know how I get on. Cheers
s80turbo
Apr 24, 2011 06:31 PM
Twill08
Mar 16, 2010 11:50 PM
nugget
Dec 10, 2008 01:53 PM
deathbots
Jan 1, 2008 02:55 PM
