Buying a 1992 960
Old Aug 30, 2010 | 07:08 PM
91shelby's Avatar
Default Buying a 1992 960
Im looking at buying a 92 960 car is extremely clean straight 1 owner car, just needs a head gasket has 194k on it, anything i should be aware of, how easy is the HG on the 2.9L? also is it worth 600$?
Old Sep 1, 2010 | 03:09 PM
91shelby's Avatar
anyone have any advice?
Old Sep 3, 2010 | 11:58 AM
91shelby's Avatar
anyone have any idea of what im getting myself into? lol plus about what kinda mileage do they get?
Old Sep 3, 2010 | 12:45 PM
zmontgomery's Avatar
does it run at all?? The timing belt is a big item that needs to be replaced every 70k. If it broke, it's going to have more problems than just a blown headgasket. Some these early year 960s also had a problem with porous blocks, which lead to blown headgaskets. Get as much service info as you can, and if it does in fact just need a headgasket it will be a great car. I have a 93 with 212,000miles on it and I just got back from a 3,500 mile trip which I averaged between 22mpg (worst) and almost 27mpg (best)
Old Sep 3, 2010 | 03:05 PM
91shelby's Avatar
luckily the timing belt didnt break and just the headgasket went, the car has 194k on it but i know it has a lot of life left it, and with being as clean as it is and being a 1 owner car i figured I'd save it, otherwise the junkyard wouldve just parted it out.
Old Sep 4, 2010 | 12:37 AM
for $600 go for it then. If you do the work yourself, it shouldn't be too much to take care of the headgasket
Old Sep 7, 2010 | 08:26 PM
'92 960 Needs the timing belt replaced every 50k. https://www.customers.volvocars.com/...intenance.html
Old Sep 12, 2010 | 06:49 PM
skwoodrow's Avatar
When I replaced my TB, it came with the reccommended interval of 30k miles. Also, you might want to have a head shop check out your head and make sure it's not warped or cracked. The shop I used charged me 200. New headbolts, spring for them. The bolts are a torque-to-yield and once used, they are stretched. One tool you will need is a degree indicator. The headbolts get turned a given amount of degrees for the final tightening. I just replace all my valves in mine in Feb. and then two weeks later drove it 1,000 miles without any issues.
Old Sep 13, 2010 | 09:44 PM
91shelby's Avatar
also is there like a cam balancer or something, i found something that looked like a harmonic balancer but looks like the bolt pattern of the cam
pachamama
Aug 4, 2015 04:38 PM
spdekold
Aug 5, 2010 03:24 PM
gabyman97596
Feb 10, 2009 03:38 PM
tekenidiver
Nov 8, 2006 06:05 AM
960Novice
Feb 2, 2005 02:49 PM
