Power lead for my amp in a 240 Wagon
Old Apr 25, 2006 | 08:43 PM
brohism's Avatar
Default Power lead for my amp in a 240 Wagon
I've got a 1985 240 wagon, and I'm trying to run the power lead for my amp. However, I'm having trouble finding a spot in the firewall through which I can run the lead. What's the best way to go about doing that?
Old Apr 25, 2006 | 09:34 PM
Default RE: Power lead for my amp in a 240 Wagon
Look for a Rubber plug already there that you can work with.
If not then you will have to drill one then install a rubber plug with the wire.
Old Apr 27, 2006 | 02:43 AM
dmelvi007's Avatar
There are 2 rubber grommets on either side of the engine bay. I have the same car and I have power going through the one on the passenger side of the car, there are less wires to deal with.
Old May 22, 2006 | 12:51 PM
luckytweaker's Avatar
what gauge is the power lead? i ran mine in my 79 244 sedan with the hood release. there was just enough room to run it through with the hood release cable, but it was an 8 gauge wire. like the otheres said, you may need to drill a hole through the fire wall.
Old May 22, 2006 | 07:30 PM
cbevis's Avatar
dmelvi007's got the right idea....plenty of room left in the passenger side rubber grommet
Old Aug 9, 2006 | 10:57 PM
ko_kidd's Avatar
Would the idea be the same for a 740?
Old Aug 10, 2006 | 12:24 AM
ORIGINAL: ko_kidd
If you open the hood and look at the firewall on the drivers side. You will see a grommet that has extra holes that are capped off. Trim one and slide the wire in.
Old Aug 10, 2006 | 03:13 PM
tech is so smart. i love him.
Old Aug 15, 2006 | 08:47 PM
ko_kidd's Avatar
Yeah, this guy has some great advice.
aytchgee
Dec 30, 2009 11:58 AM
fredbyte
Nov 3, 2009 08:51 PM
dsuk
Jul 14, 2009 01:07 AM
richsmif
May 9, 2008 08:45 AM
floryed
Apr 7, 2005 12:22 PM
