Go Back   Volvo Forums - Volvo Enthusiasts Forum > General Volvo Forums > New Members Area
Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 07-15-2006, 04:00 PM
comp27409 comp27409 is offline
Default '94 volvo 850 turbo
I just bought a 94 850T which had a smoking problem, lot of smoke when idling blue/white in color. A local mechanic checked it and found lot of oil in the intercooler pipes, cleaned all the pipes and pulled the turbo and recomended a turbo rebuild. I bought the turbo repair kit and had him rebuild it and now again the car is smoking again and oil is in the intercooler pipe again.
This is my first volvo, it has 165k miles, shift great and in very good shape. What should I do to get rid of this problem??Any advice will be appreciated.
Old 07-15-2006, 07:08 PM
tech tech is online now
Default RE: '94 volvo 850 turbo
Have the Vent box checked and make sure it isn't clogged.
How long did you drive it before it started smoking again?
__________________
1995 Yellow T5-RM yes Manual
1996 850 turbo
Old 07-15-2006, 07:43 PM
I drove the car for about 100 miles and thought the minimal smoke which was coming out was from the accumalation in the exhaust after the first turbo failed. This morning I checked the intercooler hoses and are filled with oil.
Where is the Vent box located?
Does it mean the rebuild turbo have failed again?
Thank you.
Old 07-15-2006, 08:37 PM
No it doesn't.
The Vent box is located on the front of the engine. Down under the Intake Manifold.
Like behind the A/C compressor.
Also make sure all hoses coming off of it are clean and not clogged.
If the Vent box is clogged it will suck oil into the system.
__________________
1996 850 turbo
Old 07-15-2006, 08:52 PM
I will look at it possibly tommorow sometime and see if the vent is clogged up. I also noticed oil was leaking from a tiny hole in the base of the radiator. This hole is not as a result of damage,it seems the radiator came with it because I had to replace the radiator when I bought the car. If I block the tiny hole the car seems to produce more smoke. Is this hole supposed to be open?
Old 07-15-2006, 09:07 PM
That is the intercooler and yes the hole is supposed to be there to Drain excess oil.
__________________
1996 850 turbo
Old 07-15-2006, 10:01 PM
Thank you so much, I will let u know what I find out about the vent tommorow.
Old 07-16-2006, 02:08 PM
Hi,I am unable to locate the vent, could it be the one where the oil cooling line from the radiator are screwed on.On my car is behind the right front wheel beside the a/c compressor and is screwed just above the oilpan and the oil filter. I checked under the intake manifold and could not find it.
Old 07-16-2006, 02:17 PM
It is very hard to find. I have inserted a Diagram of the setup.
It is located on the front of the engine when you look at it.Really side of the engine front of car.
Also some pics of it with the Intake manifold removed.
[IMG]local://upfiles/853/E4BC2BE589FE41E081A5775FE60F9337.jpg[/IMG]
[IMG]local://upfiles/853/4E2672EC2CB24601B43C9B7A7389246D.jpg[/IMG]
[IMG]local://upfiles/853/46AD1E23E45D4F66816AA9A346135B42.jpg[/IMG]
__________________
1996 850 turbo
Old 07-16-2006, 03:13 PM
Thank you sir,I now see where to find it.
Tags
1996, 850, 94, air, area, conditioner, diagram, engine, imglocalupfiles853e4bc2be589fe41e081a5775fe60f9337 jpgimg, intercooler, kit, performance, problem, rebuild, rebuilt, turbo, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
