1992 Volvo 740T Wagon Brake Question
Old 08-10-2007, 12:02 PM
otis44's Avatar
Default 1992 Volvo 740T Wagon Brake Question
I have a 92 Model 740T wagon which I have owned for approx 7-8 months. When I bought the car the guy said the rotors and front pads were new. Upon getting the car I had my mechanic do some preventative maintenance to the car and he looked and the front brakes and confirmed they looked new. They have started squealing to high heaven. I took the front tires off today and the pads and rotors do look new. The rotors on the mic have a thickness of 26mm. According to a chart I found here on the internet the correct thickness on a new 740 rotor should be 22mm with an absolute min of 20mm. (This is is Girling w/abs by the way).The chart shows a thickness of 26mm for rotors on a 900 series for the same vintage. My question is is is it possible these rotors are wrong all together, should I have these turned and install new pads?Also what is the proper torque on the lug nuts, I believe I read 62lbs, and when taking these off i'm pretty sure they exceeded that. Any ideas or advice is appreciated. Thanks in Advance
Old 08-10-2007, 12:39 PM
billofdurham's Avatar
Default RE: 1992 Volvo 740T Wagon Brake Question
Specs from Volvo for 740, 940 and 960are: Girling vented 26mm, discard at 20mm.
Torque for lug(wheel) nuts 63 lbs/ft or 86nm. In my experience most mechanics do not use a torque wrench as often as the DIY man.
BBslider001
06-16-2014 01:02 PM
otis44
07-26-2012 10:48 AM
pierce
01-10-2011 07:36 PM
goodboyz358
07-15-2010 10:50 PM
nola740T
02-11-2009 07:32 PM
Quick Reply: 1992 Volvo 740T Wagon Brake Question
