88 244 DL seat heaters
Old 01-23-2011, 07:00 PM
c4rpe_d1em's Avatar
Default 88 244 DL seat heaters
The seat heaters seem to not be working. The fuse is the same as the fuel injection system and I believe the turn signals (not sure). But i do know the fuse works. Could it be the wiring in the seats?
Old 01-24-2011, 07:02 AM
act1292's Avatar
There was a post late last year on brickboard that pointed to a writeup on CleanFlameTrap.com describing typical failure on these. Basically, the wire breaks off near the thermostat on the seat heater.
I recently repaired mine. Unfortunately i could no longer find the post on Brickboard (it seems that only recent posts appear there). Basically you remove the rod that holds the seat cover bottom on. This allows you to slide out the heater unit. From there the repairs are simple.
If you go over to Brickboard and message Art Benstein, he can provide a link to his site where he has pictures that show how to do it.
Old 01-24-2011, 10:31 AM
c4rpe_d1em's Avatar
Default thanks
Oh wow, ok....thanks for the info!
Old 01-26-2011, 04:14 PM
act1292's Avatar
I was able to dig out the link that I used to fix mine.
http://cleanflametrap.com/seatHeater.htm
donf
06-26-2010 08:53 PM
denver005
01-07-2010 09:49 AM
tedr
10-20-2009 02:11 PM
cheggers
02-16-2008 12:01 PM
Benji9k
12-22-2004 08:36 PM
Quick Reply: 88 244 DL seat heaters
