90 240 DL Wagon Starts,Runs,Stalls
Old 07-19-2014, 11:34 PM
urbanfinch's Avatar
Default 90 240 DL Wagon Starts,Runs,Stalls
Hello Everyone,
Its been a year since my timing belt problem, and everything has been great
till now.
The car will start and run for 15 min or so then stall and will not start up again at least not rite away, give it 30 minutes and it starts, I've cleaned
the air flow sensor, it seemed to help. Any ideas or suggestions would be
appreciated ,
Thanking You in advance, Kathleen (AKA ;Urbanfinch
Thanking You in advance, Kathleen (AKA; Urbanfinch
Old 07-19-2014, 11:43 PM
might be a heat related problem, like heatsoak on the CPS sensor and its wiring. or something in the ignition system is failing when its hot, like the power module, or coil.
Old 07-20-2014, 06:10 PM
urbanfinch's Avatar
Hi Pierce, Do you mean the Oxygen sensor in the exhaust system? or the coil
Thank you Kathleen
Old 07-20-2014, 06:36 PM
CPS == crankshaft position sensor. its located on the back of the head, stuck down into a hole on the transmission mounting flange, and reads notches cut into the flywheel/driveplate ... this is used on all LH 2.4 cars (1989+) instead of the hall sensor in the distributor that was used on LH 2.2 (up to 1988).
anyways, the CPS wiring is notorious for deteriorating, and its in a place thats not easily seen or accessed.
here's a bad CPS out of the engine,
and where it fits on the engine (with the engine out of the car as its nearly impossible to see in place)
ahall
12-05-2020 05:59 PM
urbanfinch
07-24-2014 11:40 AM
740Hiiliard
07-30-2012 06:36 PM
drnan
09-03-2009 10:34 PM
9engel
10-09-2006 11:50 PM
Quick Reply: 90 240 DL Wagon Starts,Runs,Stalls
