84 240 starts but stalls
Old Sep 2, 2009 | 08:36 PM
drnan's Avatar
Default 84 240 starts but stalls
Hey guys I have had a stalling issue only when cold. At first I could not get the thing to start all of the time. I found a bad coil and replaced that. It now starts but stalls until it warms up. If I give it gas it sounds like it is misfiring. Once it is at regular operating tempature the problem is gone and does not come back ever. It has what appears to be a good cap and rotor, good fuel pumps, new plugs. Any help would be greatly appreciated. I have searched the threads but have not found my unique (I think) problem.
Thanks again in advance.
Old Sep 3, 2009 | 05:09 PM
fredbyte's Avatar
Not sure about 1984, but my old 1982 had a cold start injector and thermal time switch, each of which could lead to your problem.
Old Sep 3, 2009 | 06:37 PM
drnan's Avatar
thanks I will look into tracking down those things and checking them, any idea where they are located?
Old Sep 3, 2009 | 07:56 PM
TURBO 245's Avatar
Is your car a turbo?
If it's non turbo check your coolant temp sensor,located under #3 intake runner.Check the wires to the sensor for fraying,84 models are known for having biodegradable wiring harnesses.
Dan
Old Sep 3, 2009 | 10:34 PM
drnan's Avatar
Ok I will check that sensor tomorrow, yes it is a non turbo, and the wiring harness looks a little worse for ware.
urbanfinch
Jul 24, 2014 11:40 AM
urbanfinch
Jul 20, 2014 06:36 PM
KatieK
Nov 11, 2010 10:29 PM
Old740
Jul 15, 2008 08:15 AM
am0858
May 3, 2006 09:18 PM
