'93 940 odometer broken
Old 06-28-2005, 06:07 PM
pisque's Avatar
Default '93 940 odometer broken
My odometer stopped working but my speedometer still works. I read somewhere that the green gear splits. I opened the odometer and removed the little motor with the worm gear that drives the green gear. Now, when I turn the green gear, everything works. Could it be something else broken ? Any suggestions will be appreciated. Thank you.
Old 06-28-2005, 07:46 PM
Default RE: '93 940 odometer broken
The motor might be bad if everything else is working properly.
Old 06-30-2005, 03:03 PM
Al's Avatar
Al
Al is offline
I recently went through a similar issue on a 240. Many postings regarding this issue call attention to a gear that splits / cracks, teeth break off, etc... of which then renders the odometer useless - however, the speedo is unaffected. This gear is underneath the motor, housed against another gear. In my case, the suspected gear was in fine condition. The culprit was a spring. Attached to the motor is a unit that has a spring in it. I removed this unit and the spring, stretched the spring out, pieced it togehter, and all has worked fine.
Sofar.
12-01-2008 10:40 AM
jvcski
11-01-2007 07:14 AM
joanvito
07-18-2007 08:31 PM
88_240_DL
03-26-2005 03:14 PM
j410b
09-08-2004 12:01 AM
Quick Reply: '93 940 odometer broken
