Odometer Broken?
Old Oct 28, 2007 | 04:02 PM
jvcski's Avatar
Default Odometer Broken?
I don't know what to do I do not want to fix this myself, the job seems to detailed for me. Does anyone know what a Dealership will charge me to fix. I live in New Hampshire if that makes a difference. Thank you
Jason
Old Oct 28, 2007 | 04:47 PM
RedTurbo850's Avatar
Default RE: Odometer Broken?
I don't know how much the dealer charges, but i'm sure they will over charge you badly for it...
It can't be that hard to fix. Compared to some of the other repairs, it is simple. Isn't it just a matter of undoing a couple screws to get the cluster out and then unscrewing the screws on the cluster and taking the cluster apart and replacing a gear?
Even a non-mechanically inclined person should be able to do this in 2 hrs max.
Old Oct 28, 2007 | 08:10 PM
Check out my post about removing the dash pad. That will help to do it.
Old Oct 31, 2007 | 01:01 PM
mhphoto's Avatar
Ugh, my the local dealer here told me it would be $800 because they had to replace the entire instrument cluster. I had to keep myself from laughing.
Two independent shops quoted me $200 and $300.
Old Oct 31, 2007 | 01:44 PM
axelm's Avatar
Maybe it is standard Volvo procedure to change the whole instrument cluster.
Old Nov 1, 2007 | 06:01 AM
JPN's Avatar
JPN
ORIGINAL: axelm
Or may be it is some sort of conspiracy.....[8D].
Parts & Procedure:
http://www.fcpgroton.com/volvo850gearinstructions.htm
$25 + shipping for new odo gear.
All you need: Torx tools & attention to detail. Be sure to disconnect the negative battery cable but make sure you have the code for radio before undoing the battery. Also, the engine will have to re-learn idle speed.
Good day & keep warm,
JPN
Old Nov 1, 2007 | 07:14 AM
axelm's Avatar
ORIGINAL: JPN
ORIGINAL: axelm
Exactly, that´s what I meant. Considering that many many cars have broken odometers, they should sell the gear or the odometer casing instead of the whole cluster.
Sofar.
Dec 1, 2008 10:40 AM
joanvito
Jul 18, 2007 08:31 PM
pisque
Jun 30, 2005 03:03 PM
88_240_DL
Mar 26, 2005 03:14 PM
j410b
Sep 8, 2004 12:01 AM
