fuel pump relay
the 960/940SE relay panel is on the right side of the transmission hump, readily accessible if you remove the passenger side foot well cover.
on a regular 940(and 740), you remove the ashtray and the cigar lighter/cubbie box above it for easiest access. the cigar lighter + cubbie comes out if you remove the plastic bezel around the cigar lighter then the screw under it.
1995Volvo850
09-28-2022 12:20 PM
montysano
09-09-2008 11:52 AM
