soft pedal 93 245 w/abs
Old 09-08-2005, 11:31 AM
ibob's Avatar
Default soft pedal 93 245 w/abs
93 245 w/ abs.I replaced rear calipers and master. bleed order right rear, left rear, right front, left front. Master was bled. Still have no pedal
Old 09-08-2005, 08:15 PM
Default RE: soft pedal 93 245 w/abs
No fluid leaks? Sounds like a air leak/vacuum type problem. I'll look up your brake system, and try to post back in a few minutes if I find something more specific.
Old 09-09-2005, 12:21 AM
ORIGINAL: matthewensey
Might be a fluid leak at the proportioning valve/block. Those are hard to see.
Ibob, is your pedal firm until you start the engine? If so that could be the brake booster/servo.
Was the soft pedal the reason you replaced the rear calipers, or did this symptom occur AFTER? Sometimes it is best to pressure bleed from the calipers to the master...removes more air.
HTH
Old 09-09-2005, 02:31 PM
ibob's Avatar
yes the pedal does feel firm until I start the engine. Is there a way to confirm that it is the booster and could it be a vacuum leak?
Old 09-09-2005, 08:49 PM
It could be a vaccum leak or a booster.
But if you shut the car off the pedal should be soft for one or 2 pushes and then it will get hard as you use the reserve vaccum in the booster.That is normal.
But if you shut it off and let it sit for about 1 min and then try to hit it and it is stiff then the booster or something like that is bad.
Old 09-09-2005, 09:58 PM
ORIGINAL: ibob
Well, my 940's brakes feel the same as yours then. I complained here when I first got the car, got the same answers.
My next step will be to replace the vacuum booster check valve and the hose from the booster to the manifold. I never got around to it, though...I've kinda gotten used to it soft feel. They DO stop OK.
If you do it post the results!
Crown114
07-27-2009 02:38 PM
daver80
07-13-2009 10:25 PM
krs2
05-25-2009 08:14 AM
cruzcountryxc70
Engine & Internal
04-28-2008 05:42 PM
hosey82
08-01-2007 07:40 PM
Quick Reply: soft pedal 93 245 w/abs
