960 stumbles, then dies
Old May 16, 2012 | 06:35 PM
960 rookie's Avatar
Default 960 stumbles, then dies
Hi All-
Been a while since I've been on here- the 960 has run well until recently, now she had developed this random stumble and shut down issue. Only does it at idle or at a stop light, and always starts right back up. Dies quickly, almost like turning off a switch- not like running out of gas or something, although there is a stumble just before she dies.
Seems to run fine on the road- doesn't die when driving. So far all I have done is to remove the idle control valve and clean it up a bit. Didn't help.
Anyone have a similar issue? I know it's not much to go on...
Thanks-
Brady
Old May 25, 2012 | 08:36 AM
960 rookie's Avatar
Really? No one has any thoughts or had a similar problem? Looking for some ideas here..
Thanks
Old May 27, 2012 | 08:09 AM
Henry10's Avatar
This forum hasn't worked right for a while. Even before that, this forum has a limited number of people.
Culprit can be many things. It can be Coolant Temp Sensor, wires, spark plugs, fuel pump, injector(s), busted vacuum line, throttle switch connector, etc. etc. etc.
You need to tell us a little more. What is you vacuum at rough idle? Fuel Pressure? Have you pulled any codes? When was last tune-up?
Old Jun 25, 2012 | 07:05 AM
marauderx's Avatar
Have you cleaned your flame trap? That solved a lot of running issues with us...
Old Jul 18, 2012 | 08:14 AM
T77911S's Avatar
try the fuel pump relay.
Old Aug 8, 2012 | 01:53 PM
97volvo960's Avatar
with your model year...just like mine 97 ..my fuel pump gave out around 137K miles...with that exact symptom.
estreet1
Jan 16, 2012 01:33 PM
free1959
Sep 11, 2011 02:59 PM
karutunian
Mar 13, 2010 08:11 PM
ATL_S80
May 24, 2008 12:32 PM
joker834
Jan 8, 2007 08:34 PM
