s70, cranks, revs, idles, stumbles then dies
Old Aug 12, 2010 | 02:30 PM
estreet1's Avatar
Default s70, cranks, revs, idles, stumbles then dies
I;m working in a 1998 s70 with a non-turbo 2.4 engine. Original complaint was no start after initial start up. Discovered fuel rail not charged with fuel, changed the fuel filter, car started strongly the began running rough and eventually died. After several more starts, stumbles and die outs hookedup a coe reader and 4 codes: cyl misfire on 1, cylinder misfire on5, random/multiple cyl misfires, and fuel too rich bank 1. Replaced plugs, wires, cap and rotor, car started strong but continued to run rough,stumble and die. There is a common link to this condition and i was thinking cam shaft position sensor failure, ignition coil failig or an ECM problem. Want to know if i'm on the right track and looking for other possible solutions. Estreet1
Old Aug 12, 2010 | 07:00 PM
chachouu's Avatar
Banned
Check the spark Plug wires first,most likely they are connected wrong
Old Aug 14, 2010 | 11:27 AM
estreet1's Avatar
chachouu, do you know the firing order and which end of the engine is the #1 cylinder located. I replaced the plug wires one at a time, but sometimes it's easy to cross wire. now, the stumbling didn't start until after the fuel filter was replaced and i purged out air at the schrader valve on the injector rail and the line coming from tank into the fuel filter. Sometimes other problems develop coincidently while some problems are in the process of being fixed. I thank you for your suggestion and any other feedback you choose to share.
Old Aug 15, 2010 | 12:33 AM
gdog's Avatar
If it ran good after you did the plug wires, even briefly, then you did not cross any wires.
I am more inclined to think you're dealing with a fuel pressure issue. Suggest you buy, borrow, rent, a fuel pressure gauge and ck the pressure at the schrader valve.
A quick ck you can do is pull the vacuum line going to the fuel pressure regulator on the fuel rail (when engine not running) and see if there's fuel in there; there shouldn't be. If there is, you need a fuel pressure regulator.
Are you getting black smoke out the tailpipe?
Old Aug 15, 2010 | 05:10 PM
estreet1's Avatar
Default estreet1 reply to gdog
thanks gdog, i will do the quick check. I didn't check for black smoke but i don't think there is. When it's dying and i try pumping the pedal, it feels dead/unresponsive as if there's a big vacuum leak.
Old Aug 16, 2010 | 09:49 AM
estreet1's Avatar
Default hey gdog
Qk chck revealed no gas on vacuum side. going to rent a pressure tester and check fuel pressure. will let u no results.
Old Aug 16, 2010 | 11:12 PM
gdog's Avatar
Is this an intermittent issue, or does it run crappy all the time? More specific symptoms please...
Old Jan 15, 2012 | 10:51 PM
rreece31's Avatar
did u fine a fix for this?,,,,I'm having the same,same! problem.
Old Jan 16, 2012 | 01:33 PM
Usually the fuel pump relay under the fuse box.
nightmarevolvo
Feb 4, 2023 06:20 PM
rspi
Mar 1, 2014 06:38 PM
960 rookie
Aug 8, 2012 01:53 PM
rainman14624
Sep 20, 2010 09:22 PM
karutunian
Mar 13, 2010 08:11 PM
