97 960/S90 died and won't start
Just drove the car. It was running fine then at a stop sign I felt it miss fire a couple of times. At the next stop sign it started missing really bad and then died. It would barely start and idle rough for a few seconds and die. Any thoughts? By the way no check engine light and 3/4 tank of gas.
Thanks
Thanks
RE: 97 960/S90 died and won't start
Mystery solved. Towed the car to the mech today. After extensive trouble shooting they found the problem. Aparently after replacing the A/C compressor a few weeks ago. They (a different garage) didn't tighten a couple of grounding straps. They worked loose and walla no electric. Thanks for the help anyway!
