Air pump hose disconnected at air box
Old 05-01-2010, 09:16 PM
vjaneczko's Avatar
Default Air pump hose disconnected at air box
In swapping my air pump, I realized that I didn't order the pump mounts, so my thought is that instead of putting it all back together, I'll leave all the parts out of the car. With the hose disconnected from the airbox, I thoguht I'd cover the hole with a clean, unused rag and use a ziptie to keep it in place. My thought is that it shouldn't cause a problem because the ziptie should be strong enough to prevent the cloth from getting sucked into the engine - path of least resistance is from the air filter, right?
Thoughts?
Old 05-01-2010, 09:17 PM
That should work fine.
Old 05-03-2010, 07:35 PM
fcpgroton's Avatar
Former Sponsor
Or you could use an air filter over the hose.
slowtype
05-04-2012 06:22 PM
winston901
11-23-2011 12:09 AM
tomecsi
10-27-2011 07:56 PM
CyDetrakD
01-21-2009 11:58 AM
Justin325
11-21-2006 10:47 AM
Quick Reply: Air pump hose disconnected at air box
