how to remove 5 spd shifter knob?
Replacing gear **** and gaiter
To remove gear shift ****
-Cut off the outer casing on the **** with a knife
-Remove inner sleeve using pincers so the locking groove is exposed.
-Remove ****.
To remove gear shift gaiter
-Remove cover under parking brake lever
-Detach gear shift gaiter from center console by pressing on rear of the gaiter on the snap fasterners from below via the hole under the parking brake.
-Pull off gaiter from the gear shift.
-Remove ****.
well good news guys. after a day of trying and getting pissed off i got it off without cutting the leather. i used a small flat head screw driver and pryed under the **** where the c clip is . if you pry it far enough away from the shifter you can pull the handle out. it was still hard to pull out but i got it off in one piece.
