Just Bought 2000 C70 Problems
Old 12-12-2016, 06:15 PM
xerxes66's Avatar
Default Just Bought 2000 C70 Problems
Looked at car & it idled smoothly - sputtered and stumbled when I tried to rev engine and then "ran out of gas". Bought it anyway, put in some gas, and got it 500' away to a station & filled with gas - now it will idle but will not rev enough to drive home!
Any ideas?
Also, heater/AC system will not turn off so I pulled the fuse.
Thank you very much for any help!
(Tomorrow I have to call AAA to get it towed home unless there's something simple a forum member might know about)
Xerxes66
Old 12-12-2016, 10:34 PM
Joe7Bros's Avatar
Bad fuel pump, bad fuel filter
Old 01-16-2017, 09:00 AM
Jhardy's Avatar
I just bought a 2000 c70 as well,car is in really good condition,the Ars light just came on,is there a way for me to clear it so I can get an inspection
Old 01-18-2017, 09:05 AM
Not sure what you mean by Ars light. If you mean SRS, its indicating an issue with one of the airbags or supplemental restraint sensors. Not all OBD2 readers can view/reset so I suggest going to a dealer or Volvo friendly indy to get the codes read and reset. Some big box auto parts stores will also scan codes for free. If there's truly a fault (which is likely) the code will reset right away and you need to replace the indicated part or its related wiring. If its the ABS light, then you either have an ABS pump issue or the ABS controller. ABS controller faults may also present both ABS and the traction control light - and possibly a check engine light (for a speed sensor ).
Old 01-18-2017, 09:29 AM
Jhardy's Avatar
I meant srs,fat thumbs,tiny keyboard lol. Car passed inspection with that light on,thank goodness. I only paid $1200 for the car would hate to pay a lot to fix a sensor
Old 01-18-2017, 05:04 PM
in my case, I had to replace a side air bag in the driver's seat to get the code to go away. Sometimes you can get lucky and find a dirty or loose connector. A simple thing to try is to check under the front seats to see if a connector got kicked out of place. The codes will tell you which SRS component is suspect as well.
Old 01-18-2017, 08:41 PM
xerxes66's Avatar
Default Madness has struck!
I started this post when I bought the 2000 C70. I've done the following: New knock sensors; fuel filter; pulled & cleaned PCV system; new alternator; cleaned throttle; cleaned MAF sensor;hours of work and it still will not accelerate past idle. I'm going to pull the cat converter next...
Can anybody give me some ideas, please...
Thanks in advance.
Old 01-19-2017, 05:08 AM
ES6T's Avatar
A professional diagnosis can go a long way.
New throttle? New fuel pump? New MAF? All possibilities.
Old 02-01-2017, 05:26 PM
xerxes66's Avatar
Another followup - new electronic throttle ans MAF sensor - runs great when cold and begins to stall when it warms up !!
Maximum frustration...
Old 02-01-2017, 05:47 PM
ES6T's Avatar
Fuel pump relay?
1speedbike
04-17-2013 05:48 AM
Bernie Caplan
06-04-2012 01:42 PM
Fidelis79
05-05-2010 02:36 AM
Volvo V70R
04-11-2007 04:57 PM
postdoc99
04-27-2006 10:33 PM
Quick Reply: Just Bought 2000 C70 Problems
