Vvt timing pulley wobble
Old 07-05-2009, 08:28 AM
mick1232's Avatar
Default Vvt timing pulley wobble
I have a c70 and the VVT pulley is wobbling there is play in all directions only alittle, ive never stripped 1 of these off is it a sign of wear or do these pulley move alittle (floating) the belt isnt running in a straight line as it comes over the vvt pulley to the other camshaft pulley i know that isnt good ,Is it worn out
Old 07-05-2009, 11:16 AM
Are you moving it with the belt off?
Old 07-05-2009, 12:49 PM
mick1232's Avatar
ive moved it with belt on 1st then i took off the belt and checked it again ?
Old 07-05-2009, 01:26 PM
Well with the belt off it will turn foward and back some which is normal.
If it wobbles with the belt on I think something is wrong.
Old 07-05-2009, 01:53 PM
mick1232's Avatar
the procedure for checking a wheel bearing is up and down and side to side ! thats what im doin on this pulley and there is movement (play) with and without the belt so it F----d then ?
Old 07-05-2009, 02:43 PM
Could be. Still seems really strange though.
Old 07-06-2009, 12:15 PM
mick1232's Avatar
R u a technician TECH ?
Old 07-06-2009, 09:04 PM
Yes for about the last 15 Years on Volvo's only.
Old 07-11-2009, 01:53 PM
mick1232's Avatar
Well if i was you i would walk out now and become a courier or somthing what do ya do all day wash volvo's cause wi ya knowledge to say ya have 15yrs on volvos is POOOOOOOR man
Old 07-12-2009, 08:49 AM
Why do you say that?
Old 07-12-2009, 08:56 AM
mick1232's Avatar
Tech ya have never helped me out man ! ya either dont want to or its cause ya dont know. I went to my local volvo dealers regarding that vvt pulley and they told me straight away
Old 07-12-2009, 09:01 AM
What was wrong?
I guess you never took my advise then I thought I helped out out on the running problem post a while ago. Just because I might not know about your car does not mean I do not know nothing.
The other thousand or so people on this board will disagree with you on that one.
Old 07-12-2009, 10:50 AM
bw77's Avatar
I have learned a tremendous amount about fixing my car by reading this forum over the past few months. The advice that Tech and many others offer is top notch. This forum is about sharing what you know to help others.
Advice is not perfect. It's hard to diagnose a problem that you don't see first hand.
If you learned something about the vvt pulley from your dealer, I hope you will share that with us.
Old 07-13-2009, 04:25 AM
mick1232's Avatar
ok sorry for the frustration first i took out on Tech ! and the answer i got from volvo was the VVT pulley DOES have play only change it ifs its noisey thats it really but i read onother forum that there should'nt be any movement at all so says 4 different garages in my local area
Old 07-14-2009, 07:24 PM
Correct it should not have any play at all. If you remove the belt you can roll the pulley foward and back only like if you were trying to spin the pulley and cam. It should be that way to adjust timing while the car is running. Oil pressure is what adjusts the timing.
lkatze
07-31-2023 12:07 PM
Hopper
1998-2000 model year V70
09-15-2012 10:48 PM
donovan72
09-11-2012 12:43 AM
russellsv40
06-02-2011 12:02 PM
olddaddy
01-25-2011 10:37 AM
Quick Reply: Vvt timing pulley wobble
