help - Key stuck in the ignition. 2001 S40
I have a 2001s40. Today I went to move my car and the key was stuck in the on position. I had to disconnect the battery just to shut it off. The key is still stuck in the on position. I tried wd40 and tapping on the key. As well as moving the steering wheel back and forth. I can not get the key out or even move it to the 1 or off position. Can anyone help me?
There is a cable that locks the ignition / key. A Volvo mechanic told me to cut the cable once I had the key out. That worked. There is also a little piece of metal that breaks off in the bottom of the ignition and gets jammed in the cable end. I seen a write-up on Matt's site where a guy cut a small plate under the ignition and pulled that broken piece out and all was well.
key drama
When the ignition failed in my 2000 V40 my Indy Volvo mechanic said it was a common prob as these vehicles age...expensive repair.
In luck as mine failed only 5 miles from my mechanics shop. There was no indication of a problem before the failure.
Flipping n-mare if this had happened out on the road...towing and ordering parts.
volvoloco
06-27-2011 07:44 PM
